2014 Camry Blend Door actuator
Does anyone know where the actuator is located on the 2014 SE? Today my air wouldn't turn on until I was in gear and moving and when I tried to adjust vents it just blows through the main ones on the dash. Heat is a little sticky to when going from hot to cold. I was told there are 2 actuators one being main and the other for recirculation. I think the main one should fix the issue but I don't know where the part is located. Any help would be greatly apprectiated.
It’s manual. I was able to locate the unit today and when selecting a venting option the plastic gear tries to move but doesn’t. The heat control and recirculating option works so I’m not sure what the issue is at this point.
