7th Gen (2012~17) Oil Filter Housing Removal Tool
Old Aug 31, 2019 | 09:32 AM
cmk033's Avatar
Default 7th Gen (2012~17) Oil Filter Housing Removal Tool
There is a tool to remove/install the filter housing. The one that is offered form Toyota is over $40. I've purchased one on-line for around $10 without much success. The tool works to remove the housing. But then the toll is stuck there and I have a hard time removing the tool from the housing after the housing is removed. Then the bigger problem is is that when the tool is used to install the housing with a new filter. The tool is stuck there and I cannot seems to be able to remove the tool from there. Cheap tool.... I am wondering if anyone had success getting a tool that works for less to remove filter housing?
Old Aug 31, 2019 | 01:28 PM
Might bite the bullet and get a more expensive tool.
Lisle 61040 - 65mm 14 Flute End Cap Wrench Toyota
jackddo
Jun 6, 2015 10:11 AM
crazylove
Jun 21, 2012 04:06 AM
crazylove
May 6, 2012 08:02 PM
crazylove
Apr 25, 2012 09:48 PM
bosulli
Feb 7, 2007 12:16 PM
