96 Camry oil leak
Old Aug 29, 2009 | 07:28 PM
rocksfield's Avatar
Default 96 Camry oil leak
New to the site,my 96 camry is leaking oil, it seems like its coming from the valve cover gasket. I would like to change it my self, just need info on the importance or what i should do or not do.
bless
VC
Old Sep 10, 2009 | 06:02 PM
captainkickass's Avatar
just get those rubber oem gaskets from autozone and change the o-rings while your at it. Just make sure you read your repair manual to see what to torque it to. You DO NOT want to overtorque it because it will crack. Make sure you use a torque wrench. If you don't have one you can pick one up for cheap at autozone. Its a really easy job to do.
woody1953
Mar 20, 2011 09:21 PM
allwired
Apr 24, 2007 05:57 PM
geoffg
Nov 29, 2006 10:13 PM
lesaroka
Sep 12, 2005 10:58 PM
