Strange oil leak in 95 camry, need help
Old Apr 23, 2007 | 09:03 PM
allwired's Avatar
Default Strange oil leak in 95 camry, need help
I have a 95 camry with a V6 and automatic transmission. I had what I thought was a rear main seal leak where it was dripping every once in a while. I brought it to a mechanic's shop and they replaced the rear main seal, put it back together, now the oil is pouring out while running.
My first thought was the obivious "they messed up", so they pulled the trans down again anf took a look at the seal. the seal is bone dry, but there is oil coming out of the bolt holes from the crank. I've never seen this and my mechanic hasn't either, we figured sealing the flexplate bolts would clear the problem. No dice!
Has anyone ever heard of the 3.0L cranks going bad, or some procedure to correctly seal the back of the crank? any help would be immensely appreciated.
Thanks
Old Apr 24, 2007 | 04:19 AM
toyoboy's Avatar
Default RE: Strange oil leak in 95 camry, need help
i had it happen on a 4runner..but sealing the threads on the flywheel fixed it....so i don't know what to tell you
Old Apr 24, 2007 | 02:10 PM
allwired's Avatar
do you know what type of sealer was used?
Old Apr 24, 2007 | 05:57 PM
toyoboy's Avatar
my dealer calls it F.I.P.G....i think its a silicone base product..(but don't quote me on that)...
davidmpetit
Mar 20, 2015 10:52 AM
wtdboss01
Oct 10, 2013 06:20 PM
richc333
Jul 12, 2010 12:12 PM
hayhayday
Jun 15, 2009 06:31 AM
