96 Camry replay multi-function switch
Old Jun 20, 2016 | 12:15 PM
wannakatana's Avatar
Default 96 Camry replay multi-function switch
I can't find anything on how to do this. I tried to get to it at a junkyard, seems I have to remove the steering wheel? And it looks like that whole circular switch assembly has to be replaced? $270 new
The turn signal is the problem, when turning right, it seems to short out and all the lights go out unless you jiggle the switch or move it back to the neutral position.
The 97 looks so much easier, apparently only a screw on the side to remove the switch. Just my luck to get one that's much more difficult.
Old Jun 21, 2016 | 10:25 AM
There are two screws on the front of the steering column covers. Determine if you can rotate the steering wheel to gain access to the screws.
Old Jun 27, 2016 | 07:39 AM
I've removed all possible screws/bolts. The assembly is donut shaped. I see no way to remove without removing the steering wheel first. It's the assembly which has the turning signal stalk and wipers stalk attached.
sonafish
Dec 10, 2012 09:20 PM
gilhouley
Jun 19, 2012 06:21 AM
FEDUPBIGTIME
Oct 21, 2010 08:39 PM
yauyauyauyau
Jul 21, 2009 05:44 PM
lurchbird
Mar 9, 2008 12:34 AM
