97 Camry front end damage
Old Apr 9, 2011 | 02:26 PM
Matttj's Avatar
Default 97 Camry front end damage
Hey guys. This past fall my girlfriend hit a light pole with my camry. It sat in my driveway over the winter and about 2 months ago I found a car for parts. For the most part disassembling the 2 have been easy so far but I have run into a problem. The Long U shaped bracket (?) that has the hood latch on it is attached to some paneling that the fenders are screwed/bolted to. Forgive me for not knowing the name. I didn't find any screws holding these together, but noticed there was an adhesive of some kind (Urethane I assume) and so far have not been able to get them to separate. First I tried a thick scewdriver and a chisel only to have the handles of both be taken off when trying to remove them. I then tried using a propane torch to soften/burn up the material but nothing. Is there some other way to go about this? If it is urethane I don't know of any solvent that would be able to remove this.
That bar/brace in front there with the dent near the center is what I am talking about.
Screwdriver bit stuck in the drivers side.
Top down shot. Bumper and bumper support have been removed.
Old Apr 9, 2011 | 07:11 PM
If you are talking about the photo with the stick the parts are spot welded together. Every dimple in the metal is a spot weld.
You need to drill out the welds, there cutting tools for this. Do a Goggle search.
Jigglypuff
May 5, 2014 05:21 AM
OLDSHOMAN
Aug 19, 2010 12:34 AM
mirro79
Feb 25, 2009 04:22 PM
jbishop1
Aug 20, 2007 12:50 PM
Ahkwa23
Dec 4, 2006 08:30 PM
