99 camry with shift problems HELP!
Old Jul 22, 2011 | 12:11 PM
judijaz's Avatar
Exclamation 99 camry with shift problems HELP!
ok so after installing a new battery, the car alarm went off..so disconnected it. car starts fine--runs fine but,,while in drive ..apply brake,,shift into park..and it dies..the noise it makes is the same noise you hear if you try to start your car while it is already running,,,it does this when you shift into any gear and then dies . So when I am driving when I park-it dies,,then start and reverse,,then put in drive--dies ? also it is not throwing any codes so i have no clue what is happening ..i did not re-connect the alarm could that be the problem? PLEASE ANYONE HAVE ANY IDEAS??? I AM DESPERATE!!!
Old Aug 5, 2011 | 01:10 PM
mmprince4000's Avatar
If equipped with the engine immobilizer, do you see a security icon?
And yes I would re-connect the alarm.
Christi
Jul 25, 2020 08:49 PM
judijaz
Jul 21, 2011 11:44 AM
mryang91
Nov 3, 2010 10:52 AM
ARGuck
Jul 13, 2009 10:12 AM
