AC Button Replacement on 98 Camry
Old Oct 29, 2022 | 01:02 PM
hippieelmo's Avatar
Default AC Button Replacement on 98 Camry
Wanted to know how the AC button can be removed off the climate control cluster. The light doesn't work and all the coloring is gone from mine, was looking at replacing judt the button and the bulb.
Thanks
Old Oct 29, 2022 | 03:33 PM
Auto or manual A/C? Manual has 3 rotating ***** and some push button switches. Assume its manual.
You might pick up some kind of service manual to follow.
The finish panel around the *****, switches and think radio below it plus storage bin needs to be removed. To do this requires sliding a thin plastic tool or such between the panel vertical edges to push in built-in plastic clips on the panel to release the panel. GENTLY do this!!!!!!!!
Once the finish panel is off remove the screws on the side of the unit having the *****. Remove the three ***** as there is a screw behind two or more of them. Remove screws.
Pull out panel having *****/switches. Keep in mind there can be a push/pull cable connected to one of the *****.
The A/C button housing pushes in from behind the unit and locks in with built in clips on the button housing. Use a tool to push the clips in and pull out the push button switch unit from behind.
Remove the wiring connection to switch.
Old Nov 8, 2022 | 09:03 AM
gareth cage's Avatar
how did that work out for you ?
Campho
Apr 13, 2022 07:57 AM
Igor Savchenko
May 13, 2021 11:55 AM
Franco
Aug 23, 2007 01:15 AM
donlaziejoker3
Mar 29, 2007 01:40 AM
johnnee
Dec 8, 2005 10:57 AM
