Broken Lower Bolt on 2001 Toyota Camry V6 Transmission to Engine Interface
Old Jun 6, 2020 | 10:29 PM
  #11
Good job on getting the bolt out!
The bolt torque is for the type of bolt used. One can torque it to a lower value.
The smaller bolts as for the converter shield are typically just hand tightened by feel.
Old Jun 6, 2020 | 10:54 PM
  #12
whealthy's Avatar
I noticed my transmission drain plug kept forming a drop on it over time so I took it out to find a gasket. To my surprise a significant amount of aTF started coming out. I drained it before I took it out. I ended up getting a quart and a half. The only place that fluid could have come from is possibly some from the differential but most would have been from the torque converter. Now I am worried that there won't be enough ATF in the torque converter.
Old Jun 7, 2020 | 12:54 PM
  #13
The torque converter can't be drained in car. The fluid must have been from the differential area. If the differential does not have a fill port use the trans dipstick to check fluid.
Make sure the trans does not have a separate differential fill port. If it has separate fill port then use this to add fluid to the differential. If not use the trans dipstick.
tromso
Oct 15, 2017 01:38 PM
oakla
Jun 4, 2017 01:27 PM
oldad
Dec 31, 2012 01:06 PM
jrider
Oct 11, 2012 10:47 AM
demiandvm54
Nov 17, 2011 09:51 AM
