Camry engine swap help
Old May 21, 2018 | 05:11 PM
Tubsurfer's Avatar
Default Camry engine swap help
I have a 2003 camry with stripped head bolt threads in the block. Seems to be a common problem with the 4cyl engines from this year. Can anyone tell me if the motor from the year models before this one will bolt right up? Like the 4cyl from a 1998 model
Old May 22, 2018 | 11:14 AM
The Camry engine model was changed in 2002. Earlier engines are not the same model.
Have you considered repairing the block threads. This is now a common DIY job.
Prior to the head bolt threads failing, how was the engines oil consumption? Some engines also suffered from high oil consumption.
Old May 22, 2018 | 11:03 PM
Tubsurfer's Avatar
oil consumption is normal. How can I repair the the threads in the block? Helicoils?
Old May 23, 2018 | 11:27 AM
Suggest NOT using Helicoil.
Some have used something called a Time-Sert. There are also kits put out by vendors, one being called NS300L for this engine model (2AZFE) which have longer inserts.
Search the net under "repairing 2AZFE head bolt threads." You will find posts, video's, etc on repairing this engine. This site has a lengthy thread on this issue.
The cause of the head bolt thread issue may be poor design combined with uneven heating of the head, the type of head gasket used and low coolant.
Read as much as you can on the subject before buying anything.
The link below provides a decent overview:
Toyota 2AZ-FE Stripped Block Threads (AKA Stripped Headbolts)
Relizondo
Dec 26, 2017 06:04 PM
ellimist98
Aug 15, 2009 08:57 PM
carlos1787
May 23, 2009 05:57 AM
scotbot
Sep 12, 2006 09:31 PM
