Cleaning Battery terminals!
Hi All ,
i noticed the battery positive terminal have too much rust and i'm going to clean it up and surely i'll disconnect the battery while cleaning .
do you think any settings will be lost when i disconnect the battery ?
i don't want to be surprised when i reconnect my battery again and found something doesn't work , please advise .
Camry 2004 ,
watzmann
Camry 2004 ,
watzmann
from experience
radio code security can be lost
if your radio has this type of anti theft feature
.make sure you have the numbers in hand and instructions how to re enter
4-Cylinder?
If so the computer will need to relearn engine idle and trans shifting patterns.
All radio settings will be lost.
If your cleaver you can connect a small jumper wire between the plus battery terminal and the cable terminal before disconnecting. Or install a trickle charger on the plus cable terminal and negative battery terminal or connect to chassis ground.
Over time the computer will relearn on its own. Mean time the idle may be rough, engine have performance and shift problems. Sometimes the throttle body needs to be cleaned to get the idle OK.
You can't find a section of wire? It need not be a jumper cable as your not going to start the engine. The amperage will be much less then one amp.
the desolate one
Sep 7, 2019 03:36 PM
2007xle
Aug 7, 2009 09:50 PM
marc780
Apr 10, 2006 06:22 PM
