driver's side vent always on
Old Apr 13, 2023 | 01:03 PM
etspam's Avatar
Default driver's side vent always on
Hi all-
Tried going through search, but can't find specific info. We have a 2004 LE - regardless of what I set the air to blow to (lower/upper), the driver's side vent is always on. The center and passenger vents work correctly, in that if I change the direction to the lower setting (towards feet), the air cuts off. My understanding is turning the **** will trigger some motor to move dampers and such to turn/redirect the air flow to the appropriate section. I assume the motor, or whatever does it, is broken or stuck in a single position (up towards body). Can anyone point me to wiki, youtube, or schematic of where this is located and/or the part #? Would be much appreciated, thanks.
ET
Old Apr 13, 2023 | 06:46 PM
There is a side vent damper for each side vent. The side vents branch off the center vent which is a different vent then the defrost vent.
Search under side vent damper motor, year and model of car. The servo motor may be bad or the rod that connects the motor to the vent flapper fell off.
The car is generation 6 and 2002 to 2006, thus info for any of these years should apply. Toyota has used the same vent system for a long time thus any info on Camry may help.
Chao.0724
Jan 7, 2023 04:17 PM
C908
Jan 11, 2022 04:07 AM
Wilkoester
Mar 11, 2021 09:32 PM
rayr1031
Jun 24, 2013 09:37 PM
imupabove
Sep 12, 2009 03:00 PM
