Engine Drain Plug location - 2012 Camry, 4 Cyl
Old Oct 9, 2017 | 07:42 PM
Camryfan515's Avatar
Default Engine Drain Plug location - 2012 Camry, 4 Cyl
want to flush the cooling system on my 2012 Camry, 4 Cyl but can't find the drain plug on the engine block. Any help or directions or a picture on how to find it will be appreciated.
Old Oct 10, 2017 | 11:47 AM
Lower portion of front side (facing radiator) of engine. Need to remove under car plastic panels to access.
Old Oct 14, 2017 | 07:39 PM
Thank you for the tip but I couldn't find it there. My 2003 Camry's engine plug was at lower portion of the front.
Is it possible that they have totally eliminated the drain plug? after all dealership shops never use it, they vacuum the old antifreeze out.
If there are any pictures or other helpful posts, I can crawl under the engine again to search for it.
Thank you
Old Oct 14, 2017 | 09:04 PM
Try looking in water pump area. If nothing there is none.
LetterX
Sep 24, 2010 04:54 AM
bigernie46
Sep 2, 2009 12:24 PM
jderrick
Jan 19, 2009 06:36 AM
dakota7557
Oct 20, 2008 12:10 AM
irvjr
Nov 18, 2006 11:18 PM
