Old Aug 26, 2015, 03:44 PM
How-Tos on this Topic
Browse all: Exterior
Print Wikipost
Front Brake Grind
Old Feb 15, 2012 | 07:36 PM
  #11
Hippo393's Avatar
Red face
Thanks for the in-depth possible suspects, Joey. The rotors and pads are new...I changed them because I thought those were culprits, but the same symptoms before and after. No grooving on rotors before or after. Also, yes I do know the awful sound of bad CV joints; this doesn't sound like it. The backing plate idea was a good one as that may be spot-on...as a rusted-out backing plate made similar noise on my Prizm (Corolla) a couple months ago.
But, this past week was a very busy one at the house and I haven't had a chance to put 'er up on jackstands. So instead I drove the Camry in the hopes of sticking my head out the window to hear better where it's coming from. Amazingly, the symptoms have subsided almost entirely by driving it. Perhaps it was a rock jammed in somewhere that dislodged, I dunno. Maybe the backing plate rusted off and finally fell off, lol. But whatever the case may be, the car stops and steers great...that's what I have been most concerned about. I'll update should something go awry. Thanks everyone! Sorry about the red herring.
Old Feb 15, 2012 | 08:19 PM
  #12
full house's Avatar
That didn't sound good... continue updating us I'm learning
Old Jul 9, 2012 | 05:26 PM
  #13
Hippo393's Avatar
Talking
You could have a bad wheel bearing. This can make a grounding noise but more often a roar that fades into the road noise at speeds around 35 mph. When driving, rapidly turn the steering wheel to shift the body weight from one side to the other. When the weight is on the side of a bad bearing the noise will get louder, when off the bearing softer.
Yep, that was it alright. The noise gradually got worse over the months, finally took it to a shop. As soon as he lifted 'er up, he grabbed the wheel and watched it wobble back and forth! I missed it all the times I'd lifted 'er up because I always loosen the lugnuts before lifting, so I wouldn't have noticed it. Disaster averted.
Thanks toyomoho and gang!
-Alan
juarez1980
Nov 22, 2017 08:18 PM
rapala13
Oct 3, 2013 04:49 PM
foxyroxy111298
Nov 6, 2011 08:44 AM
Slammer
Aug 17, 2011 10:59 AM
nickf829
Oct 3, 2010 01:36 AM
