front corner light set removal 2000 camry
Old Sep 14, 2009 | 03:46 PM
rycam2000's Avatar
Default front corner light set removal 2000 camry
I am trying to remove both of the clear plastic semi-wrap around front park-signal light units. They appear to be held in with a plastic lug, that is attached to a bar that comes off the unit. I tried, sort of gently, prying it up, but don't wish to break them. Is there an easy way? Thanks, N
Old Sep 21, 2009 | 04:22 AM
Gregorius's Avatar
Phillps head screw mounted horizontally under the hood holds a 3/4"wide rounded plastic tab. It's the only screw you need to remove. Take it out and the side marker should pivot out a little and slide forward..
Pwrhouss
Jun 3, 2014 06:35 AM
EZDriver
Nov 5, 2013 09:28 PM
jnortonjr
Mar 17, 2012 08:20 AM
2000camry@le
Oct 9, 2010 11:37 PM
leos_camry
Jul 8, 2009 08:23 PM
