Klunking Noise
Old Dec 26, 2015 | 12:48 PM
1989_Camry's Avatar
Default Klunking Noise
1989 Camry with 148k miles. This just started two days ago.
Klunking noise when foot on brakes and nearly stopped and when starting up. Occurs mostly when beginning to drive and comes from rear, likely right rear. Sometimes sound is metallic. Occasionally, there's a deep, single thump, then the noise stops. I looked at underside (without removing tire), but didn't see anything. Tire/wheel looks intact. No changes to/work on car recently. Thoughts? Thanks!
Old Dec 26, 2015 | 03:22 PM
dirty hands's Avatar
worn brake discs or rotor
rear shocks
ceased calliper
worn rear bushes
loose wheel nuts
if the noise was the front area .. it might be the CV joints
Old Dec 26, 2015 | 06:47 PM
1989_Camry's Avatar
Thanks. A retaining pin for the rear brake shoe came off and the front brake shoe disintegrated. Just bought new brake shoes and spring/hardware kit. Have Haynes Manual, but last time I did rear brakes was 1991. Haven't found Youtube video for the 1989 Camry. Any tips, especially things not in Haynes?
Old Dec 26, 2015 | 10:39 PM
lucky the rotors were not warped or damaged
1989 TOYOTA CAMRY
http://www.toyotapartsoverstock.com/...ey_model=15428
to replace the pads normally
lower of the two smaller bolts on the calliper undo.. back off the top bolt .. swing up the half holding the pads
G clamp to compress the piston in
fit the new pads
drop back in place
fit the slide bolts
torque up
taking the whole calliper off is harder
two larger bolts to undo calliper and then try to line them up to tighten on with new discs
Old Dec 26, 2015 | 11:48 PM
1989_Camry's Avatar
Default Clarification
This car has brake shoes and drums.
Tips for doing shoes/drums?
Not sure if drums are damaged; will check in AM
Old Dec 27, 2015 | 03:18 PM
For rear drums
hit the drum with a rubber hammer
if the drum wont come off
you need to back of the ratchet adjuster of the shoes
to do the shoe holding pins
I hold the back of the pin at the backing plate
use pliers on the metal cap,,,, push in and twist till the head of the pin lines up with the metal cap groove (called cups in pic)
then release
hand brake cable adjuster is at the base of the handbrake arm
Old Dec 27, 2015 | 07:39 PM
1989_Camry's Avatar
Thanks. Surprisingly, the job was easy, the hardest part getting a C-clip off. The brakes are quiet and work well, and brake pedal is pretty high. However, my parking brake won't work, so I'm starting a new thread
