Low Idle rpms/stalling
Old Mar 20, 2012 | 12:31 PM
holysabre's Avatar
Default Low Idle rpms/stalling
Hi Im new here and just wanted to ask a quick question. I have a 97 camry and yesterday I found that my egr modulator was broken and went to replace it.After I replaced it and connected all hoses correctly I found that I am idling at a low 200 rpm and dying immediaately after start. Any idea what could have gone wrong? Thanks in advance for answers
Old Mar 20, 2012 | 02:31 PM
A vacuum leak or open EGR valve can cause these issues.
Unless stuck open, disconnecting the vacuum hose on the EGR valve should turn it off.
Old Mar 20, 2012 | 03:15 PM
holysabre's Avatar
Thanks I'm gonna check the hoses and try when I get home
Old Mar 21, 2012 | 10:46 AM
holysabre's Avatar
A day later: SO i found this youtube video that shows exactly what my car is doing and how to fix it...it seems it is my iac that is causing this conundrum but I am a little wary about using carb cleaner on it because I hear it can have some negative effects. Any feedback? TIA
Video in question: Camry Idle Air Control Valve Cleaning - YouTube
Edit: well it looks like even afer doing what was said in the video my car is still doing t he exact same thing as in the video still maybe my iac hasa gone bad
Old Mar 22, 2012 | 02:13 AM
If the idle was OK before the repair then recheck the repair.
Old Mar 23, 2012 | 04:32 AM
holysabre's Avatar
Thanks finally got it fixed. Turns out one of the vacuum hoses went bad causing it to do what was shown in the video. Just got a new one checked my connections and now its all better
Old Mar 23, 2012 | 10:00 AM
Good job, thanks for posting back with the fix.
Zmacs
Aug 13, 2012 07:01 PM
noel_99camry
Aug 19, 2011 09:52 PM
slvrspec8
Aug 7, 2010 09:08 AM
jmhowe
Oct 24, 2006 03:49 AM
dmend
Jul 5, 2006 01:24 PM
