Misfire -lean mixture
Old Nov 20, 2016 | 06:09 PM
Jjs28's Avatar
Default Misfire -lean mixture
Hi,
I have had a on going misfire now for awhile. Cylinder 2 and 3. Also lean mixture. The car has new coils, wires, plugs, crank sensor, o2 sensors, and exhaust. Still runs bad when it's hot or up to running temp. Engine light will flash every minute or so while driving.
Need help on this one.
2000 Camry with 2.2l
Old Nov 27, 2016 | 11:58 AM
wdc123's Avatar
Make sure you have all the right parts installed and compare old parts to new parts. I had an incorrect plug one time.
Old Nov 27, 2016 | 02:13 PM
Does the engine run rough when the check light is on and OK when off?
If engine not working at temp but OK when cold. When hot, use freeze spray to cool any suspected parts and wiring connections.
TheMechaBee
Mar 26, 2015 09:51 AM
Debunker
Jan 6, 2014 12:55 AM
Sprout
Oct 2, 2010 12:29 AM
machinehead26
Dec 26, 2009 05:56 AM
asylumscenery
Jun 11, 2007 03:37 PM
