O2 sensor on 05 Camry
Old Aug 11, 2009 | 05:25 PM
Rich's Avatar
Default O2 sensor on 05 Camry
2005 Camry LE (4cyl)
Here is a chart that shows the orginal wire color codes and their respected defined use.
http://home.earthlink.net/~jcgebhart/o2sens.html
Identification of Toyota's Original O2 sensors are:
Blue (signal +)
White (signal -)
Black (Heater)
Black (Heater
Universal O2 sensors (the one I purchased) have two whites, a black and a grey.
The Whites on the replacement universal are heaters, this I know for sure.
Black ?? Grey?? Which one is possitive/negative?
I have found another chart to identify the wire to plug locations, but my wife has the car for a few days out of town. Therefore, I can't tell which plug is in our car until she comes back :-((
http://www.automedicsupply.com/pictu...tructions5.jpg
What, besides having the engine light display would happen if the (+) and (-) are reversed? I beleive this is what I have done since the engine light comes on. The car runs great, better than new!!! But the light is an issue.
Literature with the new universals aren't even good for bathroom usage, and of course there are no numbers to call.
Oh, I know the argument about using OEM's ect, but my past experiences with six other cars have been wonderful using the universals, which by the way are either Boesch or Denyon. As to the argument about moisture I argue that the plug that comes on an OEM doesn't have a sealing gasket of any kind in them, therefore this must not be an issue with Toyota or other brands. I do however use an electrical sealant on the connectors along with heat shrinking tubing to make a solid seal. Salt from the roads is more of an issue since it allows electricity to flow more readily.
Thanks for any imput.
Rich
Old Aug 11, 2009 | 08:11 PM
Joel_CA's Avatar
Your car uses an AF (air/fuel) ratio sensor upstream of the catalyst (down stream is an 02). NOT the same as an 02 sensor and they are not interchangable. Go to the dealer and buy the right one- disconnect the battery for a minute, and you're done.
JJ
Debunker
Dec 5, 2013 03:02 PM
axlman
Jun 16, 2007 01:19 AM
bfaidherbe
Jul 7, 2006 10:59 PM
pjmcshea
Sep 6, 2005 03:29 AM
pjmcshea
Mar 4, 2005 08:53 PM
