Radiator clamp size question for 2007 camry se
Old Oct 11, 2020 | 08:50 PM
rj808x's Avatar
Default Radiator clamp size question for 2007 camry se
I'm planning on replacing my upper and lower radiator hoses (with GATES 23153 & GATES 23154) and want to upgrade my clamps to a constant tension T-bolt.
All I can find is that the Gates radiator hoses have a 33mm (1-5/16 inch) inside diameter but nothing is mentioned about their outer diameter.
Could anyone recommend a range for the clamp or a product? I have been seeing Mishimoto Stainless Steel Constant Tension T-Bolt Clamp, 2.5 come up a lot on Amazon but with a 2.48 inches to 2.76 inches clamping range, it seems like it wouldn't fit.
Old Oct 12, 2020 | 08:39 PM
Old Oct 14, 2020 | 01:31 PM
rj808x's Avatar
Yes, those have the same dimensions.
rj808x
Oct 11, 2020 03:51 PM
MMA1991
Jan 17, 2017 10:55 PM
brianjrealtor
May 29, 2011 12:02 PM
jgw01
Sep 2, 2009 06:20 PM
Octapulse
Dec 4, 2008 06:46 PM
