Replace timing belt
Old Mar 15, 2011 | 04:55 PM
Riverat's Avatar
Default Replace timing belt
Replaced timing belt on 97 camry now crank only turns 1/2 way was turning freely before! I'm stuck any help
Old Mar 15, 2011 | 10:57 PM
Did you replace the belt yourself? If so what directions did you use?
What model of engine?
Old Apr 4, 2011 | 04:43 PM
seth jon's Avatar
Either you somehow put the pulley on too tight or the bearing is shot.
Old Apr 7, 2011 | 12:04 AM
sedge04's Avatar
see if the crank turns when you turn the key. You'll need another person to watch. It should spin freely if all is well.
rockoalol
Jan 7, 2015 07:07 PM
d72hemi
Feb 19, 2013 08:26 PM
oldad
Jan 7, 2012 07:28 PM
Sailor90
Sep 7, 2009 08:22 PM
drickelton
Jul 11, 2008 10:13 PM
