Old Aug 25, 2015, 06:03 PM
How-Tos on this Topic
Browse all: Exterior Guides
Print Wikipost
Replacing exterior door handles on 1994 Camry
Old Jun 20, 2010 | 10:01 PM
okdoak's Avatar
Default Replacing exterior door handles on 1994 Camry
Hello, I'm new to this forum. My kids and nephew have 94 Camrys, and a family friend has a 95 Camry, all of which need exterior door handles replaced. I've done the front doors with no problems. but the rear doors are different in terms of getting to the bolts holding the doors handles in place. Any suggestions on how to remove and replace the rear door handes on these cars would be greatly appreciated. Thanks, Bob
Old Jun 21, 2010 | 12:21 PM
Here is what the manual has:
Remove clip
Disconnect 2 links from door lock and remove links
Remove 3 screws (these are on the side of the door)
If power lock, disconnect the connector
Remove door lock through service hole
Remove the 2 bolts that attach the door handle
Remove handle
Old Jun 21, 2010 | 08:52 PM
okdoak's Avatar
Thanks Joey. I did think that the power door lock would have to be removed to access the bolts for the door handle. Just wanted to make sure before taking it out. What is the clip that you referred to as the first step? Thanks again, Bob
Old Jun 21, 2010 | 09:35 PM
Having never done this job, can't state for sure.
On most door lock links an end clip keeps it attached to the an arm, etc. Typically the clip needs to be rotated to allow the link to be pulled out of the hole on the arm it connects to.
In the manual it looks like the end of one link may slide over a rod attached to an arm, perhaps this is what this means.
Keep an eye out for anything holding a link to the arm.
The service hole may have a cover that needs to be removed.
Manual states to apply an adhesive (Three Bond 1324) to the 3 screws (a tread locking adhesive), perhaps something like Loctite will work.
Apply grease to the sliding surfaces of the door lock before reinstalling.
Old Jun 28, 2010 | 05:49 PM
okdoak's Avatar
Default door handles on 1994 Camry
Joey,
Got it done. In forty-five minutes, it was installed and the tools put away. Got a couple more to do now for my nephew. Thanks for your help, Bob
kralon20
Apr 11, 2013 09:28 AM
stormy76
Jul 20, 2010 06:40 AM
rebsupra
Oct 13, 2008 01:12 PM
gboldt
Sep 12, 2006 12:06 AM
