Spark Plug not coming off ...Need Help Fast
Hey. I am in process of changing my plugs on 99 camry. 3 of them were fine but I can not get 4th one off. Its closest to passanger side. Anybody got any ideas? The extension does not go down on the last one like it does other 3. Any help? Need to get this one changed
Look at the end of the plug wire socket for messing pieces and around the plug for debris. It is possible for the plug wire socket to break down and leave debris around the plug preventing the spark plug socket from going all the way down.
I still canot get extension onto plug. I've tried everything I know to do and its still not biting onto plug. It looks to me like plug is bent and to me that would prevent it from going down all the way. Any ideas what I can do with bent plug and how to get it off?
Please let us know the resolution on this
This may not pertain but on my 2001 Camry LE 4-banger I once stupidly tried to change the plugs without waiting for plugs to cool down sufficiently. I just as stupidly probably torqued on one plug too hard. It's now locked in. I have another 50,000 miles on the plugs before I probably will need the valve cover or head removed to replace the plug.
Is it OK to wait until it gets to the point where I can start to feel/hear a slight mis-firing? Or would this be Stupid Move #3?
A bent plug would be very strange. Find a powerful light to allow actually see the plug. Compare what you see with a plug recently installed.
If the installed plugs were the ones recommended by Toyota (or equivalent) they should last at least 100K miles. The owners manual may state to change sooner but this would most likely be for emissions purposes.
Locked in as the plug will not rotate or rotates but sticks.
1. you sure you do not have something stuck IN THE SOCKET?
2. what do you mean "extension will not go on plug"? extension is simple metal rod. Socket does not? Sockets have simple rubber washer inside, to grab plug tip and secure it inside the socket, when pulling out. It sometimes comes loose and blocks passage inside the socket.
3. plugs don't bend. it's porcelain, not metal. they crack and break.
4. find long tweezers, but, 1st of all, do shine light inside plug tube. you may have some debris around plug tip.
manty1
Apr 10, 2013 04:54 AM
rakeshcamry96forum
Feb 25, 2010 01:32 PM
