Throttle position sensor
Im having an issue during acceleration. If I hold the accelerator at a steady spot, the engine will lack power at first, and then the power comes surging back. I was thinking that the TPS might be sending a weaker signal than it should. Is this likely?? I was told by a reliable friend that this is the issue and its worth it to have a brand new sensor installed anyway, it is a 19 yr old Camry with 177000 mi...
rt07
Jan 11, 2011 10:26 AM
