Throttle Position Sensor
I need the wiring diagram for a 1998 LE Camry six cyl. TPS plug connector. The connector has three wires going to it. I need to know what color wire goes in each position. Thanks for any help
If colors are yellow(No 1, VC), brown (No 2, E2) and blue (No 3, VTA).
Disconnect wiring harness plug from sensor. Orient the wiring harness plug so the 3 electrical pins are facing you and the pins are oriented horizontally with the plug locking device on the plug (locks the plug to the TPS body plug) oriented upward.
No 1 is the far left pin. Pins are oriented 1, 2, 3.
rt07
Jan 11, 2011 10:26 AM
