Timing Belt change for 97
Old Jul 14, 2011 | 01:24 AM
  #11
Hippo393's Avatar
Red face good tip!
Fired her up and she runs like a top. Took nasaengr's advice to try it out before reassembling everything. But now I've got it all assembled except for putting the wheel back on.....because I have no idea how to get the daggone crank bolt torqued to 159 pounds. I get to about 40 before the engine turns. Is there a simple tool to rent at AutoZone or the like to hold the harmonic balancer in place? BTW I am not fab-savvy to just make one. Tried that already and had to buy another lower timing cover (which installed nicely tonight). Please advise. Thanks!
Old Jul 14, 2011 | 02:04 PM
  #12
nasaengr's Avatar
Default hold that crank
You have several options on how to hold the crank from turning:
If a manual tranny, put it in high gear with emergency brake on.
You can make a simple holding tool as I described earlier.
Or, try a rubber strap wrench on the pulley.
A chain wrench would probably work, but you need to wrap the pulley with a rag or something so the chain does not bung up the pulley.
I saw one pix somewhere that showed long drill bits inserted in the pulley tapped holes, then a curved piece of rebar snaked around the bits to make a crude holding device.
Also read where you can jam a screwdriver into the flywheel gears.
I never seriously considered any of these last 3 options.
Old Jul 14, 2011 | 09:49 PM
  #13
full house's Avatar
I've tried some of those but m still having difficulty,I think I don't have the skill... I need assistant
Old Jul 14, 2011 | 10:49 PM
  #14
Hippo393's Avatar
I've done the flywheel-jamming trick before with another older vehicle, but how to do that on this hog? It's an automatic. Is the flywheel even accessible?
Old Jul 15, 2011 | 12:44 PM
  #15
nasaengr's Avatar
Default tool
For those of you who do not want to use the methods above to hold the crank pulley, buy this tool for about $60: Schley 64300.
Old Aug 5, 2011 | 12:23 AM
  #16
Hippo393's Avatar
Cool
I ended up using some angle-iron from Lowes to craft my own tool. That stuff buckled after about 110 lbs of torque...and that's just a guess as my torque wrench only goes up to 75lbs, and after those 75 I switched to a breaker-bar. Fingers crossed in that not becoming an issue....
As of now she purrs like a kitten. Thanks to all for your patience and advice!
-Alan
pmaharana
May 3, 2013 10:26 AM
oldad
Jan 7, 2012 07:28 PM
keyswest
Sep 15, 2009 08:18 PM
lacruiser
Jul 22, 2009 07:09 PM
jairopion
Sep 22, 2008 09:40 AM
