Tranmission issue on '92 Camry 3sfe Auto
Old Mar 6, 2022 | 09:50 AM
Jovd's Avatar
Default Tranmission issue on '92 Camry 3sfe Auto
Hey guys my '92 camry has been sitting in my driveway for a while now, usually it is able to shift in all gears ,one day i backed it out of my slanted driveway and it doesnt want to go in park, drive nor reverse( it makes a grinding noise and clunking noise when trying to place in gear). Ive double check that the shifter cables are connected and working also ,can my tranmission level cause this? really getting frustrated with this car lol thanks in advance
Old Mar 6, 2022 | 11:53 AM
Grinding noise when attempting to shift or when the car is moving?
Old Mar 6, 2022 | 12:14 PM
Jovd's Avatar
When attempting to shift ( car won't shift at all )
Old Mar 6, 2022 | 05:11 PM
If grinding when car is not moving the trans has internal damage or possible very low fluid. Could be a bad trans oil pump, trans main shaft issue or other internal issue. Don't use the car anymore until you find the problem or more damage can occur.
Can drop the trans pan and check for metal and do a visual inspection.
Old Mar 7, 2022 | 07:29 AM
Jovd's Avatar
what i find really strange that it was working an hour or two before shifting it on my slanted driveway, all of a sudden it just wont go in gear, ive check the transmission oil level to be sufficient ( can 5 year old oil cause this to go bad? )
Old Mar 7, 2022 | 11:38 AM
Worn out trans fluid does cause trans wear to the point of having problems. The issue is mileage and type of mileage on the fluid not age. If a non synthetic fluid, change the fluid every say 50K miles. Its the heat that kills the fluid as in stop and go driving (traffic jams) and pulling a trailer. Trans fluid age in years is a minor issue unless becoming contaminated or as stated effected by heat.
Do a search on the "paper towel oil test" to check fluid condition. Place drop of fluid on a paper towel and observe the color the compare to the photos found on the internet.
It is very common for a trains to work until it doesn't work. The trains functions normally then when the engine is started the trans has problems. As many have found out in becoming stranded and waiting for the tow truck.
Winmx1
Aug 9, 2022 03:19 PM
VanNguyen
Feb 2, 2018 02:31 PM
elhobo
Dec 17, 2009 05:24 PM
4race44
Jun 10, 2008 05:03 PM
GhostRyder
Jan 26, 2006 04:37 PM
