Transmission/Speedometer Issue
Old Jul 25, 2011 | 10:08 AM
camryhelp's Avatar
Default Transmission/Speedometer Issue
When Driving 1994 Toyota Corolla the speedometer will occassionaly go to zero. When this happens the transmission acts as though it was placed in neutral. The engine will rev, but no transmission. I can take my foot of the pedal, pump it, and then the transmission will reingage but the speedometer remains at zero for another moment or two. Normally the car works fine.
Could this be the transmission speed sensor causing this?
Old Jul 26, 2011 | 09:38 PM
full house's Avatar
[qoute]Could this be the transmission speed sensor causing this? [/qoute]
sounds like it is... have you tried to check if the sensor installed properly???
Old Jul 27, 2011 | 07:34 AM
camryhelp's Avatar
I checked that. I did unplug the sensor and the car runs better, but no speedometer. Do the sensor do anything else?
Old Jul 28, 2011 | 07:42 PM
Speed sensor goes to a module in the dash then to speedometer.
If the speed sensor is not working the speedometer will not work.
The speed sensor attaches to the differential which of course attaches to the axles.
jaybur_racing
Aug 9, 2008 11:09 PM
Tumbleweed
May 24, 2008 03:14 PM
JohnGreen
May 12, 2008 10:46 PM
colbetzor44
Apr 11, 2008 03:34 PM
spurlock
Jul 10, 2007 09:47 PM
