02 Sensor Location
Old Nov 28, 2013 | 05:59 PM
cgeaves's Avatar
Default 02 Sensor Location
Can anyone help me locate the Bank 1, Sensor 2 (downstream sensor) on a 2006 Toyota Camry with the 3.0L tranverse mounted V6 (1MZ-FE)? Also can you confirm that there are only 3 sensors for this engine, 2 before and 1 after?
Thanks!
Old Dec 4, 2013 | 01:51 PM
Look at engine for number of converters. If one converter per cylinder head PLUS another under the chassis could have 5 sensors. One before and after each converter and one down stream of converter under chassis.
Bank 1, Sensor 2 would be the 2nd sensor on the rear cylinder head exhaust system.
Old Dec 5, 2013 | 07:49 AM
cgeaves's Avatar
Since this is a V6 wouldn't that be 7 sensors? I've never seen a car with that many! Unfortunately this is my daughters vehicle which is 1000 miles away from me so I'm trying to help her without having the opportunity to look at the vehicle myself.
Old Dec 5, 2013 | 02:23 PM
See TSB at link below, page 6 showing 4 sensors but engine could have 5, another behind the TWC. A total of 3 converters, one called a TWC.
http://alflash.com.ua/Learn/banksengine10l.pdf
If the engine has converters on the exhaust manifold they would look like the item in the link below. The converter is built into the manifold.
06 2006 Toyota Camry Exhaust Manifold - Exhaust - Replacement - PartsGeek
The front cylinder head exhaust system should be visible with trunk open. Perhaps she can take phone photos to send you of the area.
Old Dec 6, 2013 | 01:58 PM
cgeaves's Avatar
Thanks Joey!
broncobilly
May 8, 2011 07:20 AM
JOHNNYUK
Apr 11, 2011 10:08 PM
Zapp
Jan 10, 2010 10:19 PM
broncobilly
Nov 2, 2009 09:07 PM
axlman
Jun 16, 2007 01:19 AM
