Browse all: Engine Diagnostics Guides
- Toyota Camry: Why is My Check Engine Light On?
Guide to diagnose trouble and recommended solutions.
1988 Camry Check Engine Light
Good morning,
Saying hello from the great state of Georgia.
I have a 1988 Camry LE, 175,000 miles, 4 cylinder, automatic, 1 owner. Recently the check engine light came on and when I took the car to have the emissions done, it failed. Of course it did. The usual 02 sensor problem. My brother and I checked the code and was given a code 21--02 sensor. He has installed two and the light persists. Here is my issue: The light comes on and goes out.It doesn't come on and stay. Could this be some kind of short in the system? If so, what should I have him look for? You would think if the light doesn't stay on, we wouldn't be able to get a reading, but it blinks code 21 each time. What can be done to make the light stay on?
We know how to clear the code and have done that by removing the ECI fuse and putting it back--we have done the battery thing by removing the negative--we have done the gas cap thing and the problem will not go away.
My retest expires the first of next week and I need to narrow this problem down to why the light won't stay on first. I have not wasted any money on the 02 sensor because it needed to be replaced even if it's not the problem. Please give me some suggestions, if you will.
I only need suggestions as to what may be causing the light not to stay on so that we can get a "good and correct" reading. The check engine light has a mind of its own :-)).
Thanks.
Doiche.
Thanks.
Doiche.
Good morning,
Thanks.
Doiche.
Thanks.
Doiche.
____________________________
Dont forget to say thanks!
FGTech Galletto 2-Master
sconley
Mar 2, 2012 09:33 AM
hardyrxp
Apr 6, 2010 09:09 AM
hardyrxp
Mar 31, 2010 02:10 AM
