View Poll Results: Is this common?
Ecu?
0%
Low compression?
0%
Voters: 0. You may not vote on this poll
1997 Camry random misfire on 2 &3 not coil
Old Jun 28, 2020 | 07:25 PM
97camry00's Avatar
Default 1997 Camry random misfire on 2 &3 not coil
I’m having a random misfire on 2 and 3 cylinders I’ve done a lot to this car including all new fuel lines tank pump and rail. The issue I’m having is definitely not the coil. I’m believing it’s the signal wire to that specific coil but I’m new to the Camry’s and I love this car but I can’t figure this one out and I don’t wanna throw parts at it if someone might know what it’s doing thanks....
Old Jul 3, 2020 | 10:21 PM
Any random code P0300?
Here's the list.
Ign system
Injector
Fuel pressure
EGR
Compression
Valve clearance/timing
MAP
Engine coolant temp sensor
Open/short wiring/connector
ECM
jwcamry46
Oct 23, 2015 09:44 AM
StumpDrummer
Apr 9, 2012 12:03 AM
Saltfish
Oct 26, 2009 06:23 PM
jwatson0823
May 30, 2008 11:27 PM
mpoole
Sep 19, 2007 11:02 AM
