2000 Camry Interior Electrical
Old May 27, 2007 | 11:58 AM
nbaptist's Avatar
Default 2000 Camry Interior Electrical
About a week ago I thought the altanator had gone out. Took it out and had it checked it was OK. Turnes out it was the timming belt.
After getting the new belt installed the interior lights (dash, dome, radio) along with the shifter (automatic) is locked in place and the turn lamps dont work.
The Headlights and tail lights do work.
I do recall when taking out the altanator that the power lead from the battery did come into contact with the exhaust heat shield, Big spark!
All of the fuses and relays are good, well at least they look good.
Any suggestions on where to look for an in line fuse or?
Thanks
Neil
Old May 27, 2007 | 10:28 PM
toyoboy's Avatar
Default RE: 2000 Camry Interior Electrical
recheck your fuses..i bet its one of the bigger fuses that is related to all the different components.
Old May 28, 2007 | 03:13 AM
camry313's Avatar
ORIGINAL: toyoboy
do the check by using a tester by phtting the ignition switch on without starting the engine & check each fuse terminal so u can find wich fuse is blown & as for the relay "big fuse" try swiching them if they have the same power so u can know which one to replace if it's cuasing the problem.
all the best
ssracing
Mar 27, 2012 12:50 AM
dgalla1205
Apr 1, 2011 12:52 AM
awbooth
May 23, 2010 08:19 PM
svnipp
Sep 5, 2009 09:35 PM
SupermanVR
Aug 23, 2007 07:57 AM
