2000 camry no battery light
Old Jan 9, 2013 | 01:10 PM
aachejx's Avatar
Default 2000 camry no battery light
My 2000 Toyota Camry has wired problem. It has the problem for 10 years since I bought this car salvage title in 2002.
Every time I disconnect battery to do maintenance and connect it back, and starts the car, engines stops after 30 seconds or sometimes after 3 minutes or 5 minutes when it was running on the road.
When I try to restart the car, nothing happens. There is no check engine light and starter motor does not turn. But I can see oil light on in the dash panel. Obviously there is no power to starter motor.
So what I had to do is to disconnect the battery or disconnect the main engine replay, and it starts and runs again. Then, it shut off by itself after 1 or 2 minutes.
I thought it was connection problem, and cleaned battery connector, and even changed the main engine relay. It did not help. But once it settles down after 10 times connect and disconnecting hassle, it will keep working fine for many month or one year if I do not touch battery.
Toyo dealer told me that there is no security thing installed on this model.
OBD scanner error : Link Error
What can be the problem?
the desolate one
Sep 7, 2019 03:36 PM
hplar
Aug 15, 2013 06:13 AM
tanker1975
Jun 22, 2013 12:11 PM
jbwood89
Oct 11, 2009 09:36 PM
2007xle
Aug 7, 2009 09:50 PM
