2008 Camry Alarm Issues
Old Apr 13, 2011 | 03:36 PM
ecksmanfan's Avatar
Default 2008 Camry Alarm Issues
I just purchased my 2008 Camry SE in January. When I set the alarm (lock it) the horn honks in addition to the traditional Toyota beeping. The car has an additional alarm, which I can only assume is factory installed because it works in conjunction with the key fob. I found the source of the alarm, which is installed under the steering column. When I unplug that alarm, the honking stops when I set the alarm, but now when I turn the car on, I get 3 really quick honks.
Anyone else run into this issue? ANyone know how to eliminate the problem? DOn't mind the beeping at all, but the horn is just obnoxious and annoying to neighbors and myself.
Old Dec 16, 2011 | 07:42 PM
instntkrma's Avatar
I took my 2008 Camry to the dealer today to have the honking "turned off". After linking with the computer and going through the many options, they found that this was actually not one of them. They then saw that my alarm system was not a factory alarm - I purchased this car used and the previous owner may have had this installed. The honking is a function of this aftermarket alarm. The mechanic removed the plastic panel beneath the steering wheel and found an in-line fuse for the alarm; removing the fuse disabled the alarm, but also eliminated the honking. I now get only the "Toyota beep/chirp" when locking or unlocking my car.
More about the alarm - I have a small red led light on the dash to the left of the steering wheel, near the coin tray, that would blink to indicate the alarm was armed. Now that the fuse is removed, it no longer blinks. I have no further details on the make/model of the alarm.
Aug 14, 2015 06:31 PM
consequential
Apr 21, 2015 10:44 AM
bitstone
Nov 27, 2007 05:26 PM
ernestlinn
May 30, 2006 02:25 AM
Greg55
Nov 24, 2005 03:01 AM
