88 camry electrical nightmare
Old Oct 10, 2014 | 12:00 AM
zachfarmall's Avatar
Default 88 camry electrical nightmare
Hi everyone i have an 88 camry that wont start by the key so i jump out the solonoid and it runs and revs up perfect but when i put it in drive it wont accelerate or rev up.it moves just slow. The seatbelts and heater and windows also quit working at same time.car was perfect before so i highly doubt trans issues.any help would be amazing thanks.
Old Oct 10, 2014 | 12:39 AM
Did this happen all of a sudden or did it gradually become defiant? Any recent work done?
Old Oct 10, 2014 | 06:18 AM
All at once.i bought it like this for super cheap.hoping its something stupid.
Old Oct 10, 2014 | 09:47 AM
You turn the ign key to start and nothing happens, so jump solenoid?
Do stop lights work?
Old Oct 10, 2014 | 05:01 PM
dirty hands's Avatar
if key wont work it may still be the starter motor at fault
stuff not working
time to check the fuses in the engine bay and inside
next plugs and leads and timing - I guess - if labouring under load
drives slow
if it is an an automatic
sounds like the auto tranny has gone into fail safe - will only have third gear and reverse
if it is an auto - you can replace that tranny computer
Old Oct 14, 2014 | 06:34 AM
It was the hidden fusible link coming from the battery fuses thanks everyone
Old Oct 14, 2014 | 07:46 PM
Good job in finding the problem. Thanks for posting back with the fix.
Old Oct 25, 2014 | 07:59 PM
camry-papa's Avatar
zachfarmal,
I had a similar situation with my 91 Camry in September. In my case, the 80 amp main fusible link blew because of a electrical short to ground while I was driving. Everything except the engine died including warning lights - the engine still ran but slowed as the battery depleted. I barely made it home.
Two questions: Is the "hidden" link you mention the AM1 fusible link (black wire in series connected to the 80 amp main fusible link (on the white wire from the battery)? Also, after you replaced the fusible link, did it ever blow again? (My link keeps blowing due to the short, which I haven't yet located.)
Thanks - C-P
Old Oct 27, 2014 | 06:18 AM
It was coming of the center 80 amp fuse it hidden in wiring harness
whathappenned
Dec 18, 2013 03:21 PM
wongleetoy
Aug 11, 2013 10:58 AM
timgren
Apr 3, 2012 03:58 PM
happy420
Jan 27, 2010 08:37 AM
Jeytwo
Sep 27, 2008 10:13 PM
