89 camry idiot light problum
Sometimes my battery, brake, & light out lights come on while driving. Sometimes they don't go out after starting. When they are on it isn't charging. Then they will go off by themselves & it charges. I had the alt tested & it was ok......any suggestions? Also anyone knoe the location of the blower resistor? I only have the two highest speeds. thanks
bower resistor is usuall in pass footwell in blower box close to bower motor.It will have 2 bolts holding it in place and 4-5 wire connector plugged into it/Your alternator needs to be ck'd while problem is happaening.If it is confirmed to be charging while problem is there,then you have a wiring problem to the inside of car.
hardyrxp
Apr 6, 2010 09:09 AM
hardyrxp
Mar 31, 2010 02:10 AM
