92 Camry no rpm or Ac....
1992 Camry 4 cylinders 5 speed.
First the Ac button was flashing then the whole Ac stoped blowing light not glowing RPM gauge stoped working temp gauge stoped working battery light staying on. Car will start up and drive with the problems.
AC light flashing by itself means there is an issue with the compressor or a relay but these issues would not effect or trigger any other dash lights.
Fuses would be Gauge, starter, Ign.
The water temp, tack and speedo are on the same power circuit as the fuel gauge, seat belt and oil light. Do these last item still work?
How is the alternator output, is it charging the battery?
Check wiring inside engine compartment for damage, any mice in your area?
flyboy34
07-06-2008 10:22 PM
