2007-2009 Camry Idle RPM
Old Aug 25, 2008 | 11:40 PM
arrowdragon's Avatar
Default 2007-2009 Camry Idle RPM
When you first start your car, without having anything on or clicking the gas pedal, what is the idle RPM of your vehicle.
When you reply, please include the year, model, and engine size.
ex: 2008 Camry LE V4...RPM:750
Old Aug 26, 2008 | 11:26 AM
diver1972's Avatar
Default RE: 2007-2009 Camry Idle RPM
1998 Camry LE 2.2L 4-cyl.
Itvaries basedon the ambient air temperature, of course. However, when the air temp. is about 70 to 90 degrees and the engine is "cold" (i.e. has been stopped/off for at least 4 hours), idle RPM is about 1200.
As the air temp. drops into the 50 to 70 degree range, and the engine is cold", idle RPM is about 1400.
As the air temp. drops into the 30 to 50 degree range, and the engine is cold", idle RPM is about 1600.
As the air temp. drops into the 10 to 30 degree range, and the engine is cold", idle RPM is about 1800.
I have never operated the engine at less than 10 degrees. In fact, I do not even go outside when it is that cold.
sgpilot
May 30, 2013 10:22 PM
L4Daddy
May 11, 2011 06:12 PM
L4Daddy
May 9, 2011 08:14 PM
ani
Feb 5, 2011 11:22 AM
bingroy
Jun 25, 2009 10:11 AM
