2000 Camry 4cyl LE whines at RPM range
Old Oct 21, 2007 | 11:32 PM
black00's Avatar
Default 2000 Camry 4cyl LE whines at RPM range
Lately I've been having a whine come from the car around 1200 to 1900 RPM. Under slight accelaration, but typically while I'm just cruising. I've checked the power steering and brake fluid and everything looks fine. Any ideas? I also have a CEL on and the code given was something for EVAP. I reset the computer a couple times and it comes back. So I have those two problems. Would the EVAP be the PCV?
Thanks!
Old Oct 22, 2007 | 10:40 AM
black00's Avatar
Default RE: 2000 Camry 4cyl LE whines at RPM range
The code theOBDII scan gaveis PO440 and says EVAP Emission Control System Malfunction and says the cause could be: Vapor pressure sensor malfunction, Fuel tank cap cracked, damaged or incorrectly installed, Vacuum hose blocked, cracked, torn or disconnected, Hose or tube blocked, cracked, torn or disconnected, Fuel tank damaged, Charcoal canister damaged
The gas tank cap is fine, not sure what else to check
NWiatrak
Jul 29, 2014 06:31 AM
bobioni
Jul 27, 2014 01:19 PM
seandil
Mar 29, 2011 04:04 PM
myoda999
Mar 6, 2006 08:33 PM
