93 Camry LE door locks goofy after ECU replaced
Old Oct 3, 2007 | 08:31 PM
Monguse's Avatar
Default 93 Camry LE door locks goofy after ECU replaced
I just had a mechanic replace the engine control unit in a '93 Camry LE. Now when I try to lock the doors with the electronic door lock, it locks and unlocks all 4 doors very fast and sometimes clicks them on and off all by itself and will not stay locked unless done manually for each ****. The first time it happened, right out of the shop, I manually locked all but the drivers-side door and tried the drivers side door-lock switch several times and it worked fine then. But since then, no luck.
Can this problem be directly related to the newly installed used ECU? Does the ECU control the door locks? In examining the fuse box under the hood, the fuse diagram on the inside of the lid did not indicate that any of those fuses were for the door locking circuitry. The wiring at the door hinges is encased in some kind of rubbery sheath so I haven't tried to examine the condition of those wires. Anyone have any answers or ideas?
Thanks
Old Oct 6, 2007 | 12:54 AM
toyoboy's Avatar
Default RE: 93 Camry LE door locks goofy after ECU replaced
the engine ecu should have nothing to do with the door locks...try wiggling the rubber sheath you mention and see if you get a reaction from the door lock, if you do, you possibly have a short in the wireharnes... the door control ecu is behind the fuse box in the car there's no real test for it....it could also be a short in the fuse box itself...i hope you're good with electrical..good luck
bhch142
Sep 28, 2012 12:09 PM
sstewart777
May 22, 2008 07:00 PM
henrydhiggins
Dec 13, 2007 11:38 PM
BearChest
Aug 18, 2006 03:49 PM
