HELP!!! installed a/m Fog-Light...still not working (07 Camry CE)
Old Oct 6, 2007 | 11:57 PM
vtd's Avatar
vtd
Default HELP!!! installed a/m Fog-Light...still not working (07 Camry CE)
My 2007 Camry CE has Fog-Light prewired (made in Japan).
I installed:
1_OEM stalk (lever part number: 84140-33200). (I turned the key and tested all the lights, they worked, except Fog-lights).
2_OEM Relay (part number: 9008087010, it was superceded for 90987-02027): plugged to the last plug, bottom left of ECU, right above the Parking brake (it was the only one vacant). Also tried to plug the good PRW-Relay (part#: 90987-02027): to Fog-relay plug but did not work,…. So definitely, not the Relay
3_After market Fog lights:
http://cgi.ebay.com/ebaymotors/2007-...spagenameZWDVW
-Fog lights are still not working? I even replaced the (fog light) fuse. Do you have any ideas or suggestions to troubleshoot/fix it? Thanks.
ewong1002
Aug 23, 2012 11:08 PM
mn0491
Mar 26, 2012 06:51 PM
ezekielguy86
Aug 27, 2008 11:53 PM
Teddysnca
Jul 13, 2007 10:27 AM
WillyB
May 28, 2007 02:07 PM
