AC Light is Blinks?
Old Apr 25, 2012 | 09:28 AM
dboy11's Avatar
Default AC Light is Blinks?
My 96 Camry LE 4 cylinder, AC light started blinking after a few minutes of being on, once this starts the AC unit kicks off. If the light stays on it works fine. I've tried turning off then back on works for a minute or less and starts blinking again.
Any idea what this could be? I priced the unit that the button is attached to and its a 379 bucks.
I'm hoping that its not that and maybe a relay or something else I can check.
Thanks
Old Apr 25, 2012 | 09:39 PM
crazylove's Avatar
Thanks
It sounds like a short in the wiring behind the A/C, have you ever spilled anything on it?
Try taking it apart and looking at the wires.
Though I base this on absolutely no knowledge
Old Apr 26, 2012 | 08:04 AM
boricua's Avatar
on 96 camry a/c light flash when system have a malfunction, check the a/c relay swap a/c relay whit the horn and turn the a/c on and of to reset the system , in other cases the a/c system is low on Freon. a/c relay is on the engine compartment fuse box is a light color relay normally is white, newer version is blue or purple is also name as the magnetic clutch .
Camrydriver
Oct 1, 2008 08:47 PM
AzRobert
Aug 16, 2008 02:46 PM
X53Gunner
Mar 17, 2008 06:17 PM
moh.vze.com
Mar 6, 2008 05:11 PM
Slomo_01
Jan 22, 2008 09:47 AM
