AC only blows on high
Old Aug 5, 2009 | 08:31 PM
golden99's Avatar
Default AC only blows on high
Hello all, I came over from Honda-tech to see if you guys can offer some advice as i am trying to fix my sisters car.
1. The AC only blows when the rotary **** is turned up to high. After some searching here I think the problem is the variable resistor. If I replace the climate control unit, will this fix my problem?
2. When taking out the climate control unit from the center console, how do you disconnect the slide **** that changes the air circulation?
Any help would be appreciated.
Thanks
Old Aug 7, 2009 | 05:35 AM
whip_cracker's Avatar
From what I read on Toyotanation, it'd be as simple as replacing the resistor itself.
What year and engine you running do you know? Makes a difference. I think the resistor was behind the glovebox from memory? Not too sure... have heard of the issue as I saw it on there, ask ASG14 on TN, he's pretty clever with that stuff.
Old Aug 10, 2009 | 03:47 PM
golden99's Avatar
So replacing the climate control unit will not fix the problem?
Fixitvich
Mar 22, 2015 02:14 PM
cbrredrider1
Feb 17, 2015 09:04 PM
97camry209
Mar 24, 2012 11:14 PM
pirate694
Feb 5, 2011 07:57 PM
Supra7joey
Oct 28, 2010 10:33 PM
