Check engine light but no stored code
Old Mar 6, 2014 | 07:44 AM
Street Rat's Avatar
Default Check engine light but no stored code
I get a check engine light at startup. The car idles rough and can't be driven. When I go to check the code I get a constant flashing check engine light indicating that there is no problem. What to change or check to get this car on the road for good? 1992 Camry 2.2 automatic.
Old Mar 6, 2014 | 11:50 PM
Are you jumping the connectors to get the code or are you using a an OBD scanner? A scanner should be able to pick up all codes that have not been erased. If you don't have one, I think there are some parts stores that rent them like Auto Zone. Or you can buy one which I believe is a worthwhile investment.
Old Mar 7, 2014 | 10:23 AM
Street Rat's Avatar
I've been shorting the E1 and T1 connections as specified in the service manual.
Old Mar 7, 2014 | 04:23 PM
dirty hands's Avatar
I suggested plugs leads or coil packs
after the fuel filter change
Old Mar 7, 2014 | 10:45 PM
I would get a scanner to get the stored codes and definitely check plugs/packs, can't hurt.
Old Mar 8, 2014 | 08:43 AM
Street Rat's Avatar
The plugs look good. The coil was changed about two weeks ago. Ignition wires where ohmed out and all where within specs.
Old Mar 17, 2014 | 10:22 AM
Street Rat's Avatar
I changed the O2 sensor. Even though I had no code for it. IT FIXED THE PROBLEM.
Old Mar 18, 2014 | 12:39 AM
Nice, glad to hear that everything worked out. Thanks for posting the update.
sconley
Mar 2, 2012 09:33 AM
1985sr5
Aug 11, 2011 10:32 AM
FANtomCore
Aug 25, 2010 04:32 PM
fmoadab
Sep 27, 2009 11:58 AM
kchayes3
Aug 31, 2009 08:09 PM
