Dang 02 sensor code
Old Jun 6, 2007 | 09:11 PM
Hippo393's Avatar
Default Dang 02 sensor code
Hi gang, I got the dreaded P0135 Heated O2 sensor code (Bank 1 Sensor 1), then replaced the sensor. Seems simple enough. After clearing the code, 2 drives later the code returned. Voltage and Ohm tests on the first one failed to indicate a problem, but I replaced it with a new one anyhow.
Do I have gremlins? Could there be another explanation that's tripping this code? This car doesn't get driven all that much...could that somehow contribute?
Specs: '97 Camry LE, 69K miles, originally from California.
Thanks!
-Alan
Old Jun 8, 2007 | 01:05 AM
toyoboy's Avatar
Default RE: Dang 02 sensor code
i hope you replaced the o2 sensor closes to the firewall and not the opposit side.
Old Jun 8, 2007 | 08:06 PM
Hippo393's Avatar
Hmmm, maybe I've got the wrong piece. Here's a pic of what the part I replaced looks like:
One end screws into the forward-most exhaust manifold (V6) and the other end clips into a wiring harness located about the middle of the engine bay....nowhere near the firewall. If this isn't the correct part/piece, then that'd explain alot, lol.
The Hayne's manual shows models of diffo engines & years other than my own which adds confusion. Please advise. Thanks!
Old Jun 10, 2007 | 10:19 AM
toyoboy's Avatar
both main o2 sensor are located on the exhaust manifolds...the o2 sensor you want to test and replace is the manifold and 02 sensor closes to the firewall.
Old Jun 10, 2007 | 08:18 PM
Hippo393's Avatar
Ahh, got it now. Sure enough, I had replaced the wrong sensor. Swapped out the baddie and all is now well. Thanks!
KEVAUG
Jun 17, 2012 08:01 PM
bayarea2VZ-FE
Apr 27, 2010 07:13 PM
mgoofy24
Sep 24, 2007 04:56 PM
Viktor
Sep 21, 2007 10:18 PM
myoda999
Mar 6, 2006 08:33 PM
