Doors won’t lock after changing light
Old Oct 21, 2019 | 10:35 AM
Gavolta's Avatar
Default Doors won’t lock after changing light
Hey guys good morning. Need some help. Yesterday I changed my light bulb in the gear shift box in my 1999 Camry. After I installed everything back my doors lock wouldn’t work properly. When car has power and I try to lock doors they quickly unlock. It’s almost like the car thinks it’s in gear. When I turn power off, the door locks don’t work at all. Can anyone help?
Old Oct 21, 2019 | 01:43 PM
The Computer uses a rotary switch on the trans housing in engine compartment to know what gear trans is in.
Make sure the push type door switches on the door frames are working OK. The switch tells the locking system if the door is open or closed.
Old Oct 22, 2019 | 12:10 PM
Gavolta's Avatar
Thanks for your help. I did push the frame switches in and the locks stay locked. But only when power is on. When I pull keys out and still push switch the doors won’t lock. What should I do?
Old Oct 22, 2019 | 08:58 PM
Does the car have a wireless door lock?
Old Oct 22, 2019 | 09:07 PM
Gavolta's Avatar
Nope. It’s old school. All by key or by hand
Old Oct 23, 2019 | 08:59 PM
This design has nothing linked to the trans.
The push button door frame switches are the only thing that would normally prevent the locks from staying locked (if the door was not closed).
If you had not worked on the shift console would state to check the wiring between the drivers door and chassis. This wiring can fray, short, break with the wiring harness flexing due to door usage. The result can be problems.
Johnnyrat
Apr 4, 2018 01:41 PM
consequential
Apr 21, 2015 10:44 AM
carav4
Feb 26, 2015 11:46 PM
drjpb
Oct 18, 2012 09:34 PM
vanlegr
Apr 26, 2008 11:03 AM
