97 Camry LE Passenger Frt Door Lock issue
Old Oct 16, 2012 | 05:30 PM
drjpb's Avatar
Default 97 Camry LE Passenger Frt Door Lock issue
Have a 1997 Camry LE whose RT Front door lock is not responding. It will open and close the other three doors. Drivers side switch will not open it. Using the key will open only three doors. Any ideas? Thanks
Old Oct 17, 2012 | 08:17 AM
Each passenger door lock is controlled by two circuits linked together.
The master switch routes 2 wires to the door lock system. By changing polarity of the DC power in the wiring the door lock switch will move one way or the other (lock/unlock).
There is also a 3rd power wire going to each individual door switch. When the individual door switch is used, power goes to the actuator lock based on up or down position of switch (lock/unlock) then routes back to the master control switch via 1 of the 2 wires stated above.
If the individual door switch works for lock and unlock there may be wiring problem with the 2 wire system. If the door switch works for only one position this could also be wiring problem. If neither work may be the actuator is bad.
Old Oct 17, 2012 | 12:36 PM
drjpb's Avatar
Thanks I appreciate it.
Old Oct 18, 2012 | 09:34 PM
full house's Avatar
This procedure surely work...
my neighbor teach me the same thing...
Redwire
Mar 11, 2013 09:22 PM
zmccall
Sep 27, 2012 02:23 PM
xusreltih
Apr 14, 2012 01:38 AM
Player
Nov 17, 2008 05:35 PM
KEH27
Nov 17, 2008 06:27 AM
