Headlight issues
Headlight issues
I replaced all the relays and fuses I replaced the switch when I opened the door and the lights come on they blink off and on fast when I closed the door they go off I start the car they will not turn on but if I open the door they come on and I can use both high and low beam any ideas for the new guy and it's a 1999 camry
Do the lights flash at the same rate as the emergency flashers?
Does the car have running lights or an auto headlight dim function?
The integration relay is wired between the light switch on the steering column and the taillight and headlight relays. The taillight relay powers a lot of lights besides tail.
What lights blink? Head, tail, interior, glove box, running, etc?
The integration relay also ties into the electric door locks, sun roof and other items. Do all other electrical powered system work OK and with the driver's door open or closed?
The auto light turn off system uses the driver's side door switch as a signal input. The switch is wired to the integration relay. The relay is powered by the Dome and Gauge fuses.
puffswami
11-05-2015 05:38 PM
