No courtesy lights!! Fuse keeps blowing
Old Jan 17, 2022 | 09:50 PM
mcclendo2002's Avatar
Lightbulb No courtesy lights!! Fuse keeps blowing
Recently replace sun visors, now courtesy lights do not work. Blows fuse and fuse blows every time I replace it!
08 Toyota Camry xle
Old Jan 18, 2022 | 12:44 PM
What is the name of the fuse that is blowing?
Old Jan 18, 2022 | 01:09 PM
I believe it’s the dome 10amp fuse under hood.
No middle cig lighter and all done lights and clock are not working. Had new visors put in and since then I’ve had this problem.
Old Jan 19, 2022 | 01:17 PM
The Dome fuse powers the following:
Clock
Garage Door Opener
Interior Light
Multiplex Communication System
Wireless Door Lock Control
Check interior lights to make sure there is not a short.
Do the sun visors have a vanity light that turns on. If so check for issues with wiring.
Old Jan 19, 2022 | 05:10 PM
Clock
Garage Door Opener
Interior Light
Yes my visors have lights , so I will check those out first.
My comm system works as well as my locks.
Old Jan 19, 2022 | 07:08 PM
If no cig lighter also check here. The socket can get something metal in it or fail.
Clock has two power inputs, one to turn on and other (constant powered ) to keep the correct time when ign off. Dome fuse is one fuse to clock. Also ACU-ACC, ECU-B, GAUGE 1, PANEL.
The cig lighter may have its own fuse, 15A CIG.
The complete list of non working items is then done lights, clock and middle cig lighter? Everything else works?
Old Jan 20, 2022 | 10:50 AM
Old Jan 20, 2022 | 05:07 PM
Are the no working items you listed the only items that do not work?
Knowing what works and what doesn't one can work backward to perhaps a common point of failure.
Old Jan 20, 2022 | 06:24 PM
Yes, I listed the non working items.
Old Jan 21, 2022 | 01:09 PM
Check for switch issues of dome light that has a switch for on/off/door switch next to it.
Check lighter socket assy for issues.
Jimbad
Apr 29, 2019 09:32 AM
kajun-disabled
Aug 30, 2017 01:31 PM
slbeber
Dec 24, 2013 12:12 PM
dgalla1205
Apr 1, 2011 12:52 AM
nuttintoaboss
Aug 20, 2007 08:57 PM
