No Low Beams (again)
Hi.
I've got a 99 camry with a couple of electrical issues. Some of this, I think, can be traced to the Negative cable slipping off the rod on the battery.
1) Car has refused to start. The first two times, I jumped it without noticing that the cable was slipping. The process of attaching the cables was pushing it back onto the rod. The third time, I noticed slid the cable back down and it started fine.
2) I have no low beams. On the 99, the low and high beams are separate fuses. I was told it was a 20 amp fuse, but I don't have the manual on this car. So, I checked all the 20 amp fuses I could find and they all seemed fine. When I jumped the car the first time the headlights came on.
2a) I replaced both bulbs 4 months ago. 2 months ago one seemed to die, I replaced it.
3) The panel lights behind the AC controls are out, too.
So, any ideas?
-Chris
So, any ideas?
-Chris
The running lights ARE on.
In that I can't get the bolt tight enough on the peg, should I (for the time being) wrap the peg it in aluminum foil to get a tight fit? Would this help/solve my headlight issue?
No I think it might be a problem wit the 5th generation accords... Cause my 97 low beams is bad sometime I cant even tell if my lights are on cuase I can barely see them on the road ... but Im just going to get the conversion here in awhile
bumblecat
Oct 7, 2012 09:05 PM
dsmith222
Oct 23, 2009 09:53 PM
